Coilover Question
Old Jun 26, 2008 | 11:46 AM
LR-G's Avatar
Question Coilover Question
Hello,
I just purchased a set of BC Coilovers to put on my 07 Coupe.
Do I NEED/REQUIRE anything else?
Or can I just go ahead with the install and alignment.
Advance Thanks
Old Jun 26, 2008 | 11:51 AM
Klubbheads's Avatar
install wait about 2 weeks, get it corner balanced and aligned. Coilovers without corner balance will make the car handle worse than with springs.
Old Jun 26, 2008 | 12:19 PM
LR-G's Avatar
really 2 weeks...it that b/c it needs time to settle?
Old Jun 26, 2008 | 12:31 PM
Klubbheads's Avatar
They need to settle, as far as the time goes, a week should be enough.
Old Jun 26, 2008 | 01:11 PM
LR-G's Avatar
thanks BTW I like your quote....HAHA....
Old Jun 26, 2008 | 02:20 PM
05GRide's Avatar
I just bought these for my car as well.. If you hadn't looked into this already:
Depending on how low you intend on going, you're going to need camber kits. I would get the rear one for sure because it's cheap. If you're going more than 1" drop on the front, I would recommend getting a front camber kit/upper A arms. They are more expensive but will allow you to get your front camber back in spec. SPL and 350evo are considered "the best" front kits, Cusco, Ichiba, and SPC will do, although some people have had fitment issues with the SPC kit.
I went with SPL.
Old Jun 27, 2008 | 12:35 AM
LR-G's Avatar
I went with SPL.
thanks i thought about it but i was thinking I didint need it?..
I wanted to go 1 to 1 1/2 finger above the tire. do I still need it.?
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
