Vibration while turning right and under breaking
Old Jul 1, 2008 | 01:58 PM
maomao's Avatar
I just purchased an '06 g35 coupe and it has two different vibrations. I'm not sure if they're related or not.
First: under medium breaking the front end vibrates and wobbles, and it kinda feels like the rotor may warped possibly. Its audiable and shakes the front end and steeringwheel
Second: while heading striaght or slightly to the right theres a small vibration I can feel in the fornt end. its something you can just feel a little bit but you can definitly hear it. when I turn slightly to the left it goes completely away.
Any idea what the problem(s) may be, or what I should to to find out? Thanks for the help!
Old Jul 7, 2008 | 09:49 PM
maomao's Avatar
I think its probably 1 of 2 things. It is either the breaks, so I ordered new pads and and am going to see if I can get the rotors resurfaced, or its a loose/bad wheel bearing. Anybody have any insight?
Old Jul 15, 2008 | 02:00 PM
maomao's Avatar
Ok
Ok so it turns out it was the right front wheel bearing. when I jacked the car up and took the wheel off I could whobble the rotor back and forth. Replaced it with anew hub (I bought it from Nissan same part from infiniti was $60 more), and both my problems are gone! Car rides great now! hopefully this will help anyone else that runs into this problem ever
Old Jul 15, 2008 | 02:48 PM
nghiars's Avatar
thanks for the post
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
ara777
Oct 25, 2017 01:45 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
toadfire
Sep 21, 2015 07:15 AM
mattdg35
Sep 14, 2015 11:28 AM
