Brembo's
Old Jul 4, 2008 | 07:32 PM
Solekeeper's Avatar
Brembo's
I know that these brakes come stock on 03-04's, so I was wondering how much would a set be to put on lets say an 06?
And also, whats so special about the Brembo's?
And the negatives?
Thanks!
Old Jul 4, 2008 | 07:39 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'd suggest searching in the Tech/Brakes forum under "Brembo"
There's more info than you can read in 2 hours
Old Jul 4, 2008 | 07:48 PM
Mr.GEE's Avatar
20 Year Member
They were standard on the 6MT only. They are not a direct bolt on swap. The spindle assembly has to be replaced along with the rotors. You will be better off getting aftermarket direct replacement for your particular car. Only negative is the excessive dust with the Brembo pads and you have to be very careful when removing the wheels not to hit the calipers so you don't chip the finish. They are multi piston calipers, finished with heat resistant coating. Brembo is a supplier for many of the exotic cars, so it's the name. I'm sure there are other aftermarket brake systems that will outperform the Brembos.
Old Jul 4, 2008 | 08:30 PM
GeeWillikers's Avatar
Walking The Fine Line...
^what he said.
Old Jul 4, 2008 | 10:17 PM
lirules's Avatar
i pretty much bought an 04 instead of an 06 because of the brembos...
i love names...tho.
-brand *****
Old Jul 4, 2008 | 10:38 PM
BadBoy06's Avatar
may as well buy a new BBK for the $$$$$
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
alessandro
Oct 8, 2015 09:29 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
