Brake assembly question
Old Jul 16, 2008 | 02:01 PM
MixturePinoy's Avatar
Brakes Brake assembly question
I just purchased a replacement set of rotors, calipers, brake lines, and fluid from a vendor. This covers both the front and rear. My question is about the rear assembly.. I have an 04 non brembo (5AT) coupe. Do I need to purchase the shoes for the rear parking brake drums?
Old Jul 16, 2008 | 03:14 PM
ResIpsa's Avatar
No, unless they are worn out (very unlikely).
Old Jul 16, 2008 | 03:15 PM
I'm down to 2mm
Old Jul 21, 2008 | 12:06 PM
Jeff92se's Avatar
Red Card Crew
Good thread about adjustment. Took me a long time to figure out the manual refers it as a parking brake and not e-brake!
https://g35driver.com/forums/showthr...MERGENCY+BRAKE
Dug though the manual and found the following:
Std thickness for the p brake shoe: 3.2mm
Min thickness : 1.5mm
Looks like you're okay for now and just need to adjust it. Which I also need to check and adjust. Let me know if you had to adjust the cable too. Personally, I'd adjust the drum first via the tumber and see how that works. But the manual says to do the cable first. Seems backwards to me.
Old Jul 21, 2008 | 12:53 PM
my buddy checked it out and im actually less than 1mm w/miniscule cracking on one.
Old Jul 21, 2008 | 12:54 PM
Jeff92se's Avatar
Red Card Crew
Let me know how much a new set of shoes will cost. I get the feeling mine are toast also.
redlude97's Avatar
stop driving with your ebrake on noob!
Old Jul 21, 2008 | 12:55 PM
yea.. i wish this stupid car had the ebrake where normal cars have them
Old Jul 21, 2008 | 12:59 PM
Jeff92se's Avatar
Red Card Crew
I've done this a few times. haha
Old Jul 21, 2008 | 01:00 PM
Jeff' I'll find out today how much they cost, i'll hit you up if it's a good deal
Old Jul 22, 2008 | 05:31 PM
Jeff92se's Avatar
Red Card Crew
Updates!
Old Jul 24, 2008 | 05:30 PM
he had a set for 60 bucks. but it's from some european company called Miles? They make them and usually branded them out to other generic manufactures. I seen a set at schucks for 50 bucks Linky
My stupid noob question. do i need to buy only one or two sets? probably two..
Old Jul 24, 2008 | 05:32 PM
Hai, why don't you get on a stool and suck my
Old Jul 24, 2008 | 06:00 PM
Jeff92se's Avatar
Red Card Crew
I checked Napa ( I usually trust them more) but they only list the brembo equipped versions and it's a bit more.
For something like this I think Shucks is fine. Thanks
Old Jul 27, 2008 | 04:55 PM
Jeff92se's Avatar
Red Card Crew
What the hell did you do to your P-brakes man? I thought mine were toast and I even bought a new set from Shucks before doing my 06+ Z brake swap. Ends up the rears were almost 2mm anyway. Just never adjusted. The brand new ones were just over 2mm. So I'll be returning the new ones.
It was really easy to ajust the P-Brake shoes. After I ajusted them, the P-brake pedal only goes down maybe 1/2 way vs almost all the way down. I don't think anyone ajusted them. Took ALOT of turns to get them to grab the rotor.
