New suspension setup
Old Jul 23, 2008 | 05:42 PM
Klubbheads's Avatar
Originally Posted by trey.hutcheson
Yup - that's something that concerns me. I need to get some kind of camber adjustment, but that stuff is just too expensive. I might just get an alignment and go with crappy camber for a while.
with an inch drop the alignment shop should bring the back camber under -1.5 degrees and the front should be around -1.0, the toe should be within specs for both front and rear.
Old Jul 23, 2008 | 05:44 PM
Jeff92se's Avatar
Red Card Crew
But it's going to be something like 1 15/16" drop
Old Jul 23, 2008 | 05:45 PM
Klubbheads's Avatar
oh then nvm. I thought it was an inch all around. Looks like u have to deal with "race spec" alignemnt like i do and go through tires every year. That is with rotating them from side to side. U Better have some twistie roads to enjoy the new amount of grip that u are going to get.
Old Jul 25, 2008 | 06:28 PM
mesias's Avatar
I believe I have a new car!!!
I just finished swapping the suspension. The improvement in the handling is noticeable comparing with stock non-sport sedan suspension. Every single part fitted like a glove, no surprises. The ride now feels a lot more stiff, but neither uncomfortable nor bumpy. I'm a little disappointed in the drop on the front, I can now fit two fingers between the tire and the fender, but I was expecting more. In the rear, of course it looks lower than fronts, but for some strange reason the driver side sits lower than the passenger side. Any ideas? How long should i wait for an alignment?
Pictures coming soon!
Old Jul 25, 2008 | 08:40 PM
idrive_MD's Avatar
if you're confident you put it all together correctly, no need to wait for an alignment
Old Jul 27, 2008 | 05:26 PM
trey.hutcheson's Avatar
I got mine installed yesterday, front and rear, after 8 hours of work, in the pouring rain. It seems that I stripped a couple of nuts three years ago, and that put me off for a good 4 hours.
And I don't have any picks yet, but I am disappointed by the drop so far. Fortunately I don't have and discernible difference in the drop between the driver and passenger sides. And because of the rain, I haven't been able to really push the car. But it s definitely much stiffer, and IMO, the ride is quite a bit better than before(may have been my dead shocks).
Old Jul 27, 2008 | 11:01 PM
Update: I tried to put my strut bar back on this evening, and now it won't fit. The bar appears to be maybe an eighth of an inch too long now to fit within the bar mounts. It appears that the new suspension has slightly altered the geometry; I had no trouble getting the bar to fit before.
Old Jul 27, 2008 | 11:08 PM
mesias's Avatar
Try mounting it with the fronts in stands (unload suspension). Did you reuse stock front upper A arm? How is front camber looking?
Old Jul 28, 2008 | 05:00 PM
Ok, I was able to get the strut bar back on, it just required a second person to torque the bar a bit to get it to fit(wasn't required before).
As for the camber, I have no clue. I know my rear camber has taken a dump, but visually at least, the front looks good.
Old Aug 4, 2008 | 04:56 PM
Alright, it's been a week since I installed the suspension. I did an alignment last Friday, and while my camber was off, I think it's still within spec for a coupe(I could be wrong on that though). They were able to get toe, front and rear, within spec, so that was cool.
I'll try to take some pictures tonight.
Old Aug 4, 2008 | 04:59 PM
Klubbheads's Avatar
so what is the total front/rear drop compared to stock? How much camber do u have font/rear after the alignment?
Old Aug 5, 2008 | 10:48 PM
mesias's Avatar
This is what i got with the alignment. I have no sedan specs to compare them with but the car is running great:
FRONTS: (Left Right)
Camber: -0.6 -0.7
Caster: 8.1 8.3
Toe: 0.03 0.05
SAI: 4.7 4.1
Cross Camber: 0.2
Cross Caster -0.1
Total Toe: 0.08
REAR: (Left Right)
Camber: -1.2 -1.1
Toe: 0.09 0.09
I still have issues with unleveled rear, there is almost 1/2 inch difference between sides.
Old Aug 7, 2008 | 02:36 PM
mesias's Avatar
Can you post specs after alignment?
Old Aug 7, 2008 | 04:07 PM
Sure thing. I've been meaning to for a while now. Though I am a bit jealous - you're in much better shape it appears.
FRONT LEFT: before - after - range
Camber: -1.0 , -1.1 , -0.8 to 0.7
Caster: 8.4 , 8.4 , 7.0 to 8.5
Toe: 0.00 , 0.02 , 0.00 to 0.04
FRONT RIGHT: before - after - range
Camber: -1.1 , -1.0 , -0.8 to 0.7
Caster: 8.6 , 8.6 , 7.0 to 8.5
Toe: 0.01 , 0.02 , 0.00 to 0.04
Front Cross Camber: 0.0, range: -0.8 to 0.8
Front Cross Caster: -0.2, range: -0.8 to 0.8
Front Total Toe: 0.04, range: 0.00 to 0.08
REAR LEFT: before - after - range
Camber: -1.2 , -1.3 , -1.2 to -0.2
Toe: 0.03 , 0.07 , 0.00 to 0.11
REAR RIGHT: before - after - range
Camber: -1.3 , -1.3 , -1.2 to -0.2
Toe: 0.21 , 0.06 , 0.00 to 0.11
Rear Cross Camber: 0.1
Rear Total Te: 0.13
Old Aug 7, 2008 | 05:28 PM
  #30
mesias's Avatar
Did you install camber kit in the back? Your number in the rear are not that far from mines.
