Sedan Specific Suspension Question
Old Jul 21, 2008 | 08:34 PM
OCG35's Avatar
Mods, please leave it here... I've searched in the brake/suspension forum and most of that is coupe stuff...
Is anyone running Eibach Pros with Tokico D-Spec? (I'm sure there are lots)... please post impressions - ride comfort, handling characteristics - recommended or not...
I'm not looking for coilover feedback, I've read plenty...
TIA
Old Jul 21, 2008 | 08:49 PM
jimmykce1's Avatar
Most sedans here that are dropped are running 250z springs in front and coupe springs in rears. The springs drop the car 1-inch in front and 0.5-inches in the rear. The spring rates are the same as on OEM sport suspension and doesn't change the ride quality. However, it handles a lot better than the OEM sedan sport suspension springs.
Old Jul 21, 2008 | 08:51 PM
codeflux's Avatar
i was running it for a while. review with pics here:
https://g35driver.com/forums/brakes-suspension/158524-tokico-d-spec-eibach-pro-kit-sedan-review-pics-54k-maybe.html
the combo seems a bit too rough for my tastes. if the shocks are set too soft, the car bounces. if the shocks are set too hard, the car jitters. if you have sways, those play a much larger role with this setup, too. overall, i was loving the look (the drop is perfect), but was not too happy that i kept having to slow down to go over speed bumps and up my driveway.
Old Jul 21, 2008 | 09:44 PM
OCG35's Avatar
https://g35driver.com/forums/showthread.php?t=158524
I do have sways... the Eibach drops it to a decent "look"... with the OEM non-sport shocks with OEM 17" the ride was fine... now that I have 19" the ride isn’t as good - specifically over moderate bumps at high speeds (like fwy)... it doesn’t handle as well...
Did you try all variations of settings with the D-Specs and not find anything suitable?
OCG35's Avatar
I have springs - I'm asking about shocks/struts - BTW, 1" in front and .5" in rear isnt that great a look IMO.
Old Jul 21, 2008 | 09:51 PM
codeflux's Avatar
i tried softest/softest (was way too soft - very bouncy/rocky) and 4.5/4.5 turns from hard (was acceptable, but too rough - handled like a pro, but in the city driving it really sucked). frankly, i was relieved after i put stock sport suspension back on - i can live with the car now.
Old Jul 21, 2008 | 09:57 PM
OCG35's Avatar
code - I just read the full thread... looks like you went though several attempts to be satisfied and really never got there...
I'm looking for "decent" ride comfort with better than avg handling... based on the thread you linked it seems I might meet those needs with he d-specs?...
Edit: ooops, I posted this after your response above...
Maybe coilovers need another look from me
Old Jul 21, 2008 | 10:09 PM
codeflux's Avatar
i do recommend coil-overs. the trick there is that the manufacturer has already figured out all the pros and cons, the settings are done just right (supposedly), and you know what to expect. the thing with mixing and matching is that yes, you do pay less, and you do choose what your car looks like, but the handling is an undefined variable that you don't know until you actually try it.
if i had to do it all over again (and i'm not going to, at least not with this car), i'd get Tein CS, set them to medium-to-soft, and forget it.
Old Jul 21, 2008 | 10:21 PM
SDGenius's Avatar
great thread fellas, i'm gonna go w/the crap shoot... i've got Tokico HP non-adj shocks & struts on the way. hope they're a good match w/my H&R's.
Old Jul 22, 2008 | 01:42 AM
Kazaam's Avatar
Let me know how those turn out, I got the H&R's too on my X sedan. Can't do much with the X, but I can feel that my stock shocks are done!!
Old Jul 22, 2008 | 01:55 AM
SDGenius's Avatar
^^^will do
Old Jul 22, 2008 | 02:37 AM
godmans's Avatar
I have 3.5 from full frot and 4.0 from full rear (I want the rear to be a tad more soft to give the car a bit more corner exit speed). I know this might be a bit too harsh for many people, but this has been the best compromise for me in terms of handling and comfort.
Btw, I pair this up with 350z revised springs and stillen sways on Med/Med setting.
Hope this helps
Old Jul 22, 2008 | 03:08 AM
jack_burton's Avatar
I have a similar setup, tokico blues with coupe springs, and stillen sways. I didnt want to lower it that much.. Anybody getting a clunk over the driver side front wheel over rough pavement with the medium/medium setting? It's weird only over one wheel.
Old Jul 22, 2008 | 03:10 AM
jnmunsey's Avatar
So what is a godo option to improve handling WITHOUT lowering the car? The only cars that look good lowered were manufactured before 1975...imho..
Old Jul 22, 2008 | 03:41 AM
replace the shocks with higher dampening, put the coupe springs on (they literally lower the car 1/2 inch, not noticeable...sway bars too
