Floor jack for those with slammed rides
Old Aug 15, 2008 | 08:33 PM
Hollywood G35's Avatar
GREAT GREAT find!!
Old Aug 15, 2008 | 08:44 PM
k67p67's Avatar
I see you looking Viet. Thanks for turning me onto this jack!
Old Aug 15, 2008 | 08:47 PM
rookie's Avatar
I want my cookie.
Old Aug 15, 2008 | 08:53 PM
OH6 G35's Avatar
Originally Posted by k67p67
Are you referring to the forward jack points under the side skirts? If so, then definitely yes. If you are referring to the center of the front cross member, then no. That's nearly 2 feet from the front of the bumper. I am happy not to have to use my Tomioka ramps every time now.
One of the great things about this jack is that the jack frame height rises very gradually. It remains 3" or less in height from the center of the saddle to about 9" up the frame. It may not look that far in the picture but the angle of the pic skews things a little. I'm sure it's 9".
Got it!!
I was hoping that it would slide all the way to the front cross member jack point. The only way that I can reach this point is by using my Tomiokas.
This looks like the only Floor Jack that may work but boy is it "pricey"!!
K...how do you get your G on Jack Stands?
Old Aug 15, 2008 | 10:37 PM
k67p67's Avatar
^ I've seen that jack. It's like $600-$800!!!
I put my car on jack stands by lifting at the pinch weld just forward of the jack points and then inserting the jack stands at the jack points and lowering. I jack the rear at the differential housing and insert the jack stands at the rear sie jack points.
Old Aug 19, 2008 | 08:50 PM
johnjayb's Avatar
parting out soon???
Old Sep 10, 2008 | 12:43 PM
ShanesG's Avatar
Im still to low
BUMP!
Old Sep 10, 2008 | 01:01 PM
k67p67's Avatar
My Ings+1 skirts are pretty low in the front and I'm still able to get this jack under since the height of the skirt at the front jack point is barely over 2.75".
Old Sep 10, 2008 | 02:19 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
Originally Posted by OH6 G35
this jack is well worth the investment.
DK13HLQ with a rubber saddle pad runs $522 shipped.
with the car being a mere 3" off the ground in front, I need to drive up one 2x4" and I can get this jack all the way to the front cross member.
Old Sep 10, 2008 | 03:02 PM
OH6 G35's Avatar
...now, this looks pretty "interesting"!!
Old Sep 10, 2008 | 03:17 PM
nghiars's Avatar
good ole 2x4's.. I use either 2x6's or 2x8's since my rims are wide...
good find on the jack!!
Old Nov 28, 2008 | 01:38 PM
BolivianFuego's Avatar
Back up! Did anyone buy the specific Jack in this thread?
I did, and i need some times on how to release it so it lowers the car.
The damn lever when i try to turn it counter clockwise it just spins, and sometimes if lucky it will catch. Its like 30mins that my car has been up and i have been trying to line it up wiht the little spinning square inside.
I also looked at the square to line up with it at the end of the lever, and it seems like it isnt a perfect square, like its defective... maybe thats why?
Old Nov 28, 2008 | 03:52 PM
k67p67's Avatar
There is a bolt that keeps the long lever secured to the jack body. It threads into a hole in the jack body and protrudes into a recessed channel in the end of the lever to keep the lever from separating from the jack body. Is the lever installed properly?
Old Nov 28, 2008 | 03:56 PM
1180G35black's Avatar
I am glad this was bumped I have been looking for a nice jack
Old Dec 4, 2008 | 10:45 AM
  #30
imjackiechan's Avatar
where is the middle jack point?
