Sedan OEM rotor upgrade
Old Aug 18, 2008 | 09:17 AM
lexusk8's Avatar
I'm wondering if it's OK to swap the factory rotors from my '03.5 to the OEM ones from the '05-'06 sedan. The major difference here is that the '05-'06 rotors are larger and thicker which is exactly what I need. My current rotors are at the min thickness and need to be replaced ASAP, but my brake pads have plenty of life left. So if anyone has experience with the '05-'06 rotor upgrade, please let me know. Thanks
Old Aug 18, 2008 | 10:20 AM
Texasscout's Avatar
You would have to do a complete brake swap. Rotors, Calipers, pads and lines.
Old Aug 18, 2008 | 11:47 AM
ttrank's Avatar
Grocery getter
^+1
Old Aug 18, 2008 | 11:50 AM
Jeff92se's Avatar
Red Card Crew
+10. You can upgrade the rotors but you have to use the later year calipers. Which I have a set of dual piston calipers if you're interested. I have the oem lines to go with them also.
Old Aug 18, 2008 | 04:37 PM
lexusk8's Avatar
Thanks for the prompt answers guys. It looks like I'll have to consider either the entire brake upgrade from a later year model, or same-year aftermarket rotor replacement.
Old Aug 19, 2008 | 07:44 AM
LEON NYC's Avatar
Get aftermarket, some as simple as drilled/slotted rotors, with axis/hawk pads will give you quality braking...
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RedBaronK
Jul 27, 2015 03:19 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
