Dropped on TANABE DF210!!! PICS*
Originally Posted by tucked_g35
looks great. i am on the same springs and oem wheels. Looking to get 20's on. Are you looking to do the same? I'd be interested in seeing someone with df210's and 20's.
Originally Posted by asianric3boi
no i didnt get any cambers. but i know i should. but its like $500 for both front and rear!!!?
but yea i jsut need to save up, then i'll get some.
Originally Posted by nghiars
im dropped on the same springs... ur rear will settle in a couple weeks and go down about .3 inches more..its truly almost a 2" drop after it settles... if you're not gonna get both camber/toe kits, i would at least get the rears, you can find an eibach(really made by spc) for about 160 shipped so at least you can save some life on the rear tires.
yea i should get some cambers. thanks for the suggestion, 160 isnt that bad.
dang it settles in that much? good good, i want it lower
i think 19's are the biggest id go on the G because im planning to keep the body stock so im gonna need to fill up the gap as much as possible. if i go wid 20's, id be able to fill up the gap, but the car will still be kinda high, unless i get a bodykit. but 20's also look good on our G's, let me know when u get yours.
Here’s the exact change in wheel and tire radius:
FRONT: 225/40/19 245/35/20 equals to R13 inches R13.4 inches
REAR: 245/40/19 285/30/20 equals to R13.4 inches R13.4 inches (no change)
I’d still love to see a DF210 w/20’s pic.
I will get my wheels next week, so I’ll post some pics when I do.
Originally Posted by ErikB
Looks nice. How do you like those hankooks? What sizes are you running?
for the fronts, i got 225/40/19 and im running 255/40/19 in the rears.
Originally Posted by 05G356MT
how is the ride quality? i have like 55xxx miles and i am on a 35mm profile tire so its pretty rough for my taste already plus im not sure how the stock shocks would hold up
+1 on the rear camber kit, its easy, cheap, and actually NEEDED. After I lowered by car with Tein Basics, after about 7k miles I noticed a lot of uneven wear in the back. Camber kit seems to have corrected this problem.
As for the fronts, in approximately 10k miles of driving, I've not noticed any uneven side-side wear. IMO, front kits aren't needed unless you want to dial in more NEGATIVE camber.
