Can I mix 350Z revised springs with stock G35C 04 Sport springs?
Old Sep 8, 2008 | 06:48 PM
esi's Avatar
esi
I have a set of 07 Revised 350Z springs that I would like to put on my 04 Coupe. Since the 350Z springs doesn't drop the rear, would it be ok if I just swap the front springs and keep my rear stock? Thanks.
Old Sep 9, 2008 | 04:45 AM
Q45tech's Avatar
Spring stiffness must be balanced fore and aft to match the body weight. This sets the roll couple stiffness ratio and sets the under, neutral, or oversteer ratios. More importantly these ratios set the critical speed where the body does not pitch up and down on highways with periodic seams or undulations caused by asphalt machine.
Correct ratio, but stiffer than stock raise the tuning speed, obviously 85 mph might be the upward limit as even that degrades 55-65.
Old Sep 17, 2008 | 08:46 PM
Tollboothwilley's Avatar
You always talk to technical Q
I'm not sure if he got his answer in their either...not a direct answer anyways
Old Sep 18, 2008 | 01:25 PM
esi's Avatar
esi
lol yes I'm not that technical. But reading between the lines, I think he's telling me I shouldn't be cheap and I agree.
Old Sep 20, 2008 | 06:01 PM
RBull's Avatar
Rated M
yes, pretty sure the spring rates are the same for those. They are on Canadian vehicles.
Old Sep 20, 2008 | 06:04 PM
BlueDevilBAMF's Avatar
He's speaking in some kind of code... hmmm
jsimonk
Dec 22, 2023 03:49 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
xplosive1
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
