G35 Brake Fluid
Oct 2, 2008 | 05:30 PM
Just got my G a couple months ago and now the brake fluid light has come on.
Anything I need to know about changing the brake fluid? I'm assuming that I just need to fill the fluid container up to the max level.
thanks
Reply 0
Oct 2, 2008 | 05:36 PM
Sure, you can fill with any dot 3 or 4 fluid. But I'd check your brake pads for wear 1st. When pad thickness goes down = brake fluid going down.
If it's dark, a full flush is recommended.
There's also a section called brakes and suspension on this forum.
Reply 0
