Ok G35 H-Tech Owners chime in!
Oct 15, 2008 | 02:04 PM
I have searched and read and read some more.
I just bought a 2006 G35 coupe with RAS and Sport Suspension (Factory 19s).
I am looking for a set of springs that will lower the car ever so slightly. I really dont want to use a camber kit. I also do know I WILL have to get it aligned.
Here are my choices:
THe G coupe H-Techs
Pros: It doesnt lower it very much
It is made for the coupe
Cons: I am worried because the spring rates are softer then the stock sport suspension on the G35 Coupe, so I will lose some handling...........if the handling statement is true.
The 350Z H-Techs
Pros: It will lower it a little more, but not very much
It has stronger spring rates than the G style H-Techs. So, it SHOULD and I stress SHOULD handle better then with the G style springs.
Cons: It possible being TOO low.
I am running a set of 19" Volk SF winnings (19X9.5 front 19 offset and 19X10.5 rear 17 offset)
I am rolling my fenders as soon as she arrives.
So, my question is, will I lose in the handling department buying the G style H-techs because of the softer spring rate then the STOCK Sport suspension?
Any thoughts?
THanks
Joey
Reply 0
Oct 15, 2008 | 02:10 PM
get the 350z Htechs...with G35 Htechs u wouldnt even notice the drop
Reply 0
Oct 15, 2008 | 02:37 PM
yes your handling will suffer with the softer springrates
Reply 0
Oct 15, 2008 | 02:41 PM
I have the H-tech springs and it ends up lowering [ after a few months ] about 3/4 inch and ride is a little stiffer than stock
Reply 0
Oct 15, 2008 | 11:21 PM
Thanks guys..........
Heres a thought though, what about 350Z OEM springs and struts off of an 08 350Z?
Reply 0
