2004 g35 2Dr Brembos on 2006 G35?
Old Oct 17, 2008 | 03:32 PM
blackg352004's Avatar
Thumbs up 2004 g35 2Dr Brembos on 2006 G35?
I was wondering if this is compartible swap. I got G35 manual with Brembos, and my another one is 2006 G35 without Brembos automatic.
Can those calipers be exchanged or no? I saw that the break line is the same, may be take off and put on? Or does Main Braker booster needed to be changed as well? thanks for info on it
Old Oct 17, 2008 | 03:46 PM
Hi-TechG35's Avatar
verything from the Brembo setup is needed to do this swap. It is a direct fit though.
Old Oct 17, 2008 | 03:47 PM
Hi-TechG35's Avatar
Also you will need the Brembo rotors and pads.
Old Oct 17, 2008 | 03:58 PM
can those Brembo rotors and pads be used? ir it all needed to be brand new?
I mean rotors can be turned but pads new or used? thanks
Old Oct 17, 2008 | 04:03 PM
Hi-TechG35's Avatar
If the pads have some meat left to them then you should be fine. If not then replace them.
Old Oct 17, 2008 | 04:18 PM
silvernole12's Avatar
yes it will swap...
You need brembo calipers, pads, rotors, lines, and the mounting bolts for the rear calipers
Old Oct 17, 2008 | 05:17 PM
nghiars's Avatar
Originally Posted by silvernole12
yes it will swap...
and the thin metal plate to block out dust.. you dont need it per say but it would help keep the car clean.
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
BlackGee35
Jul 23, 2015 01:36 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
ResoG35Sedan
Jul 14, 2015 10:30 AM
