SPC Toe Bolts
Old Nov 1, 2008 | 03:46 PM
Tollboothwilley's Avatar
SPC Toe Bolts
Whats the difference between the stock toe bolts and the SPC?
I have a set and I'm about to install, I was just wondering what the difference is...possibly the washers?
Why can't you just use the stock toe bolts and just elongate the hole?
Old Nov 1, 2008 | 05:08 PM
darrick's Avatar
+ 1 yeah why?
Old Nov 1, 2008 | 07:04 PM
chenG35's Avatar
The SPC toe-bolt is more eccentric than the stock one, hence it needs the hole elongated to allow it to move the extra distance. The stock bolts are not as "eccentric" as the SPC ones, so even if you elongate the hole, it won't make any difference.
Old Nov 1, 2008 | 08:18 PM
G35sedan03's Avatar
and that allows the spc bolt to give you a wider range of camber adjustability.
Old Nov 1, 2008 | 09:36 PM
Dranom's Avatar
if you need soc toe bolts i have one
Old Nov 5, 2008 | 11:26 AM
i've got 2...just need to install when i install the arms.
Old Nov 7, 2008 | 04:59 PM
badnblk's Avatar
i just ordered my spc toe bolt kit just wondering cause im unclear a bit still how mant bolts come in the kit? is it 2 or 4?
Old Nov 7, 2008 | 05:01 PM
Boston's Avatar
^2 bolts, 1 for each side.
Old Nov 7, 2008 | 05:02 PM
badnblk's Avatar
cool thanks
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
