I need more toe adjustment
Old Nov 2, 2008 | 10:49 PM
cwylie's Avatar
The toe bolt is not enough. What do you guys recommend?
Old Nov 3, 2008 | 12:37 PM
str8dum1's Avatar
you dremeled out the stock hole? done properly you should have more than enough adjustment.
unless your suspension is wrecked.
Old Nov 3, 2008 | 04:02 PM
redlude97's Avatar
that isn't very much info. What are you using now? Stock, or SPC? Only other option is the SPL Parts Pro rear midlink
Old Nov 3, 2008 | 05:43 PM
cwylie's Avatar
Stance coilovers and Spc camber arms and toe bolts. I was at 2 get negative camber and 0 toe. But then I lowered it more so I am guessing I currently have about 2.5 negative camber and a little negative toe but the toe was maxed out to get to 0 before I lowered it more.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
