anyone have this camber kit on their G???
Old Nov 7, 2008 | 12:56 AM
ptd23's Avatar
Originally Posted by tragedycat
THMotorsports, they are a sponsor on here. Just go to the marketplace suspension section. They run a really good deal if you order front and rears at the same time.
which lowering springs do you have? i wanted h-techs. does it matter if i get 350z or g35 h-techs?
ptd23's Avatar
thanks i Pmed them already
Old Nov 7, 2008 | 12:57 AM
Calvin's Avatar
Overglorified Altima
Yes. Here is a current thread discussing them.
https://g35driver.com/forums/brakes-...9-h-techs.html
Old Nov 7, 2008 | 01:01 AM
tragedycat's Avatar
I have 350z H-Techs, I needed front and rear camber kits. People say you don't need them but after I dropped my car the wheels were clearly cambered inwards and I was seeing irregular tire wear after 3k miles. Do it right the first time, get camber kits regardless of drop.
Also as an side, the 350z H-Techs are bull****, I basically spent $1000 on springs and camber kit, install, and alignment, for an extremely marginal drop that is hardly noticeable. In hindsight I would've went with Tein Basics or BC Racing coils instead.
Best of luck.
ptd23's Avatar
thanks man. you answered alot of my questions and your alot of help. i think im going with the z h-techs and might cut the back ones
Old Nov 7, 2008 | 01:02 AM
Calvin's Avatar
Best of luck.
^^^lol, i started with 350 z h techs and ended up with basics.
Old Nov 7, 2008 | 01:03 AM
Calvin's Avatar
just to be clear, people with z h techs usually cut the rear spring mounts, not the springs themselves.
ptd23's Avatar
Best of luck.
so the springs are not worth it then from what you have done? i was going to do the same route and get the z h-techs and cut the back mounts
Old Nov 7, 2008 | 01:10 AM
ptd23's Avatar
i checked out the the DIY suspension section where they cut the mount on teh G with teh z h-techs and after he was done it looked like the back was lower and the front barely had a drop
Old Nov 7, 2008 | 01:13 AM
tragedycat's Avatar
Go search a couple picture threads on these springs and see if you would be happy with it. I obviously don't know how low you are trying to go. For me, I didn't want any wheel gap at all. 350z H-Techs almost got rid of my front wheel gap, but I have a 1 to 2 finger gap in the rear depending on how the springs are feeling that day which is no good for me.
Luckily I knew I was going to switch to coilovers eventually so I never replaced my OEM shocks with aftermarktes like Konis or Tokico's. At this point I'm just waiting for my OEM shocks to blow to give me an excuse to buy new coilovers. Although that could take a long time.
Old Nov 7, 2008 | 12:04 PM
penelson's Avatar
My understanding is that you can correct neg with the Cuscos, but not all the way back to OEM , and depending on your drop.
I'll be installing these with the Intense rear + SPC toe bolts in a couple weeks so I'll let you know how it works out. BTW , the Cuscos are a very solid/ well designed arm, they're not $$ cheap but I found you get what you pay for with performance parts (like everything else in life).
Worth getting? Depends on your goals. If you're trying to correct your negative camber, then no. If you're trying to add additional negative camber for track purposes, then yes.
Old Nov 7, 2008 | 12:17 PM
Calvin's Avatar
Cuscos do allow some positive adjustment, but they are not meant for that purpose. IMO, why not get something that is meant to do what you want it to do? SPL doesn't cost much more and allows much more positive adjustment.
Old Nov 7, 2008 | 12:48 PM
G35sedan03's Avatar
this thread gave me a headache lol
Old Nov 7, 2008 | 12:57 PM
ptd23's Avatar
haha i know, my bad for all the dumb questions.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
