BC coilovers.....?????......NOISE
Old Nov 8, 2008 | 11:16 PM
LR-G's Avatar
Exclamation BC coilovers.....?????......NOISE
Hello,
I got BC coils over the summer with SPC Camber kits all around.
My setting in the rears was @ 20dampening out of 32
My problem is now that, after driving down dufferin here in T.O over heavy construction and uneven roads.
I started to notice a metal clicking noise that occurs mostly when backing up and accelrating on 1st gear.
SOUND IS COMING FROM THE REAR PASSENGER SIDE.
I removed the tire and saw a screw close to the side wall of my tire.
Got it removed and patched but noise is still there.
Coming from suspension?
any help would be great.
Old Nov 9, 2008 | 02:25 AM
SDGeneralCounsel's Avatar
did you install the lower spring rubber holder on the gold base? this will be your problem, otherwise you have something definitely wrong with your car.
Old Nov 9, 2008 | 03:46 AM
redlude97's Avatar
many people have had issues with the BC suspension making noises, even when properly installed. BC can't even figure out the problem https://g35driver.com/forums/brakes-...need-help.html
Old Nov 9, 2008 | 03:56 AM
LR-G's Avatar
yea just started 2 days ago dammit.
Old Nov 9, 2008 | 04:09 AM
LR-G's Avatar
was good all summer till when i started to hit VERY REALLY BAD ROADS.
