Silly question to ask.
Old Nov 13, 2008 | 01:30 AM
NewGuyG35's Avatar
Does the tire lose air when it doesn't have the air cap thing? Someone stole the cap from one of the tires.
Old Nov 13, 2008 | 08:18 AM
Coach's Avatar
No, the tire won't lose air just because the cap is off. However...
The cap keeps dirt and crud from getting into the valve and possibly causing it to
stick open while you're checking pressures or adding air, which will can the air out.
Old Nov 13, 2008 | 09:39 AM
NewGuyG35's Avatar
I think that's what is happening already. Better go buy one then.
Old Nov 13, 2008 | 09:54 AM
Coach's Avatar
Put a little soapy water in the tip of the stem, you'll see very quickly if it's leaking air through the valve.
Be careful doing this if it's really cold out, you could freeze up the valve.
If you do find that the valve is leaking, it's not hard to take the valve core out and clean or replace it - you dont have to take the tire off the car.
If the valve is leaking it won't stop just because you put on another cap. G/L.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
