!spc Kit (help)!
Old Nov 17, 2008 | 07:59 PM
houston05g35's Avatar
!spc Kit (help)!
Just bought a spc upper control arm kit for my 05g35 coupe, im lowered on eibach sportlines. Can anyone tell me if i need to use the shims provided or will the control arms be enough camber adjustment alone.... Any help would be greatly appreciated,,,,,
Old Nov 17, 2008 | 09:55 PM
SilverG123's Avatar
Im not sure how much lower your car is with those springs but most people get back into specs without the spacers.
Old Nov 17, 2008 | 09:59 PM
Thanks, my drop is 1.6f 1.4r. Just got in my spc kit, part number is 72125. do i have the revised kit or not... Thanks again...
Old Nov 18, 2008 | 05:27 AM
Triple8Sol's Avatar
I've heard of some problems caused by those shims? You should do a search and find out more.
Old Nov 18, 2008 | 09:16 PM
SilverG123's Avatar
I dont think you have the revised kit the revised kit end with a 050. 1 inch drop adds -.84 camber 2 adds -2.12 the spc font camber arm can corret up to(not sure)without adding the spacers. I saw it somewere all check it out. But im almost possitive that you will be good with just the arm.
Old Nov 18, 2008 | 09:30 PM
I called spc and they said i had the revised kit, but who knows im not one to argue,,, lol. But just adding the arm corrects up to +1.5 degrees of camber and with the shims(+2degrees) provides +3.5 degrees of camber. I put the arms on today without spacers and was very pleased... I would rather ride with slight camber then to mess with my abs.. Just my take on it..
Old Nov 21, 2008 | 03:36 PM
G35Papa's Avatar
The revised kit is 72125. The UNREVISED kit is 72120
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
bigmike
Sep 17, 2015 01:58 PM
DRG35R
Sep 16, 2015 05:33 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
