Tokico D-Spec Shock/Spring Kit (pic request)
Old Nov 26, 2008 | 01:42 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
anyone running the Tokico D-Spec 350Z kit on their G? if so, could you please provide some feedback and pics if you have them. if anyone knows anyone running this setup on their G, please let me know. thanks.
Old Nov 26, 2008 | 04:26 PM
superchargedg's Avatar
I am running the g kit and the front drop is perfect but the rear is not as im going to have to do the spring mount mod.
http://www.dev-inspirestudios.com/ph...6_RRdBm-X2.jpg
http://www.dev-inspirestudios.com/ph...0_igp4e-X2.jpg
Old Nov 26, 2008 | 05:19 PM
EL-EE-ES's Avatar
front looks good, the back looks stock...spring mount is a must
Old Nov 26, 2008 | 07:07 PM
DRG35R's Avatar
20 Year Member
how much did it drop your front...and rear in reality. front looks good. how much was the advertised drop?
with Z kit the drop should be 1.5 front and rear from what I understand.
I like those RH wheels.
Old Nov 27, 2008 | 08:32 AM
It dropped the front a little over an inch but the back was less then a half inch.
Old Nov 27, 2008 | 09:42 AM
DRG35R's Avatar
20 Year Member
you can order the Z kit springs seperately if you want a better drop and higher spring rates. you may only need the rear, but might as well replace them all at once. here are the part #'s from Tokico if interested.
51F-P - front
51R-P - rear
I am considering these springs, but would like to see the drop on someone's car first as a 1.5 drop front and rear may be to low for roads around here.
Tukeeg35
Cooling
Oct 20, 2016 04:14 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
linedr89
Aug 17, 2015 05:11 PM
