Evo BBK Research/Dev Thread.
Old Dec 16, 2008 | 05:40 PM
  #31
Jeff92se's Avatar
Red Card Crew
Originally Posted by Canadian
My Megan BBK doesn't have any unswept area..you can barely see it in this picture..
Did you see the part where I mention 2 pc vs 1 pc rotors?
Here is the same type of setup with 2 pc
Old Dec 16, 2008 | 05:48 PM
  #32
redlude97's Avatar
Jeff ownz all in this thread, I don't even have to type anything this time around.
Old Dec 16, 2008 | 05:55 PM
  #33
Canadian's Avatar
Canada, eh?
I wasn't arguing with you..just showing you
Old Dec 16, 2008 | 06:02 PM
  #34
Jeff92se's Avatar
Red Card Crew
Okay sorry. It's for Nismo's benefit. He never believes me anyway.
Old Dec 16, 2008 | 06:03 PM
  #35
plugsnet's Avatar
Look guys... I would like to stay on topic with what im doing and not a go for it not go for it tally...
Thank you...
And no i dont know everything about the project jeff.. if i did it would be done already no?
Old Dec 16, 2008 | 06:05 PM
  #36
Jeff92se's Avatar
Red Card Crew
Answer the question then. What makes you think your custom setup will give you better 60-0 then what you have now? I assume that white coupe you have.
Old Dec 16, 2008 | 06:06 PM
  #37
Nismo G's Avatar
Nismo, you have no idea what you are talking about. ALL rotors are have a bigger area than their swept area. It's just that the rotor RUSTS where it isn't swept all the time. BTW. As long as the pad has contact area, that's what counts.
Go to a 2 pc version of that rotor and suddenly the extra swept area is almost nill. Interesting isn't it?
These are odd questions coming from someone that's making the G37 akebono brackets?
I am well aware that rotor size really doesn't matter as long as the pad is making contact with the surface, but that sure is a lot of wasted surface space and im sure they weigh quite a bit as well. Not question the "scientific" reasoning behind putting those rotors on your maxima. Just making a simple observation.
-Sean
-Sean
Old Dec 16, 2008 | 06:13 PM
  #38
Jeff92se's Avatar
Red Card Crew
Well then that speaks to the fact that the calipers are NOT too big for the rotor now doesn't it?
Not sure what that $0.2 crack is about but here's your $0.1 change back. Ever weigh those G37 14" 1 pc rotors you make the brackets for?
-Sean
-Sean
Right.
-Jeff
-Jeff
-Jeff
  #39
plugsnet's Avatar
Look dude its obvious why i think that 4 piston front 2 piston rear versus a 2/1 setup.. but you knew this..
Old Dec 16, 2008 | 06:16 PM
  #40
Jeff92se's Avatar
Red Card Crew
What is "obvious" to you ISN'T necessarily a reason to think your brake dist times will be better. Then again, you haven't read ONE thing I've been posting haven't you?
Old Dec 16, 2008 | 06:24 PM
  #41
Nismo G's Avatar
BTW. Here are some pics of my 06Z rotors before I did my upgrade. See the black painted part? There's extra unswept area that the OEM pad on the OEM brake system doesn't touch. I guess the OEM caliper is way too small for that OEM rotor also.
If i remember correctly you have a 03-04 g35 meaning that that OEM 2006 350z rotors are much larger than your 03-04 rotors. So yes i guess your right the 03-04 OEM caliper is to small for 05+ OEM 350z rotors.
-Sean
Old Dec 16, 2008 | 06:26 PM
  #42
redlude97's Avatar
-Sean
Thats an 05+ 350z caliper used in conjunction WITH 05+ CALIPERS
Old Dec 16, 2008 | 06:28 PM
  #43
Jeff92se's Avatar
Red Card Crew
-Sean
There you go Sean. Now please clarify, is this just an observation?
Because you DO know if I ran the 06Z 12.6" rotors, I couldn't bolt up the early 03 calipers RIGHT??
I suggest you stop while you're only 2 behind.
Old Dec 16, 2008 | 06:29 PM
  #44
Nismo G's Avatar
Right.
-Jeff
-Jeff
-Jeff
lol, yeah i have weighed them. That is completely besides the point though. I don't know why you are bringing that here. Atleast all of the surface space on those 14" 1 peice rotors is being used.
Last time i checked race cars don't use rotors that are to "big" for the caliper. Their **** actually fits lol
-Sean
-Sean
-Sean
-Sean lol
Old Dec 16, 2008 | 06:30 PM
  #45
Jeff92se's Avatar
Red Card Crew
BTW Nismo. YOu got the weight of those 14" rotors yet? You know, the ones to compare with my heavy 13" units?
