Ichibia Rear Camber Kit???
Can you explain to me then how you can get additional adjustment of the spc/ichiba toe bolts without elongating the hole when the OEM eccentric toe bolts already cover the whole range of the stock hole? Post the ichiba toe bolt instruction sheet where it says you DON'T need to elongate the toe bolts
i don't have the instructions to post up , but the toe bolts that came with the kits are like shaved on one side I don't know the word exactly for it , with that on the toe bolts that where able to have adjustment to toe on the rear
That is because they ARE SPC TOE BOLTS. So not explain how by magically changing the name on the box to ichiba, they can now make their full range of adjustments, while the box labeled SPC cannot, even though the bolts are the same....
That can be done with stock toe bolts. I want alignment numbers and drop amount. Otherwise I call BS. Even without toe bolts and a 0.9" drop, I was able to get my car back to OEM specs, so you are still not proving your point.
Whoa, so they are boxed as ichiba , is this because SPC sells their products mass assortments out to other companies , I see your getting a little heated on this it's ok , I did this on 3 cars and they had no problem when getting aligned, even without elongating it the alignment shop was still able to adjust the toe thats all I'm saying
As far as proving points I really wasn't trying to you can call it bs or shenaningans or whatever , it dont matter , I never said it was back to full oem specs , I said close that it could be to oem specs, I'm pretty sure its not dead on , Redlude I'm not here to fight or prove points
redlude is correct, 100% (not that anyone doubted him). If you don't elongate the holes, no point in installing the toe bolts.
I did notice the Ichiba kit does not come with the elongating template that the SPCs kits come with. At least the kit I did a few weeks ago did not.
