Recommended Spacer size?
Old Jan 20, 2009 | 03:25 PM
TurboDreamzG's Avatar
Question Recommended Spacer size?
What's up guys, need some advice on what size spacers I should get to get the closest to be completely "flush" as i can. I have 19x8.5" +20 up frontz on 245/35/ and 19x9.5" +25 in the rears on 285/35 GForce tires...here are some pictures taken, sorry for quality quick cell phone pics. Help me out guys what do you think?
These are the fronts:
and the rears:
I also plan on taking the "Stance" down alittle bit lower in the process of putting on the spacers as well. Just alittle more to take out the wheel gap that's left. I just have to adjust the coilovers a bit....sitting on tein basics by the way.
Old Jan 20, 2009 | 03:37 PM
redlude97's Avatar
20mm all around
Old Jan 20, 2009 | 06:16 PM
cool, do u guys have a certain brand of spacers to go with and where is the best place to get them from?
Old Jan 20, 2009 | 06:20 PM
redlude97's Avatar
check your wheels and see if they have recessed areas behind the spokes for the extra length of stud sticking through if you use bolt on spacers. If you do, then any of the major bolt on spacer companies are fine, I prefer Eibach, but ichiba and project kics also make nice spacers. If you don't have that recessed area, you will need to use spacers that have replacement studs, i would use eibach or H&R at that point
Old Jan 20, 2009 | 08:24 PM
str8dum1's Avatar
with a 20mm spacer in the rear and a 285 tire, you will def need some camber and flat rolled fenders to make it fit. my 275s are like a mm away from the fenders with like -1.7 degrees camber
Old Jan 20, 2009 | 08:29 PM
redlude97's Avatar
depends on the tire i guess, dropped on 350z h-techs with springmount mod, nonflat fender roll. ~3mm of clearance
285/35/19 Falken 451 9.5+5 -1.6 camber, 0.05 toe
Old Jan 20, 2009 | 09:01 PM
I have already done the fender roll on mine but it's not completely flat....just some clearance.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
