How many bolt holes for new brake rotors?
Old Feb 3, 2009 | 05:43 PM
Corrosive's Avatar
Well I purchased some rotors from the 350z forum that were supposed to be for the 03-05 G35 coupe (non brembos) and I took my wheel off and before I even started doing anything i noticed there is 6 bolts on my rotors. The 5 that bolt to the rim and one extra nut thing. Does anyone know if this is going to be a problem?
Thanks,
-Mike
Old Feb 3, 2009 | 05:51 PM
Jeff92se's Avatar
Red Card Crew
one extra = threaded?
If yes, then = a threaded hole for removing stuck rotors in the future.
Old Feb 3, 2009 | 05:58 PM
Corrosive's Avatar
Well my stockers have a threaded bolt with a nut attached... The new ones dont...
Old Feb 3, 2009 | 08:57 PM
infinus's Avatar
There is an extra hole in the rear rotors if thats what you mean:
Old Feb 4, 2009 | 09:10 AM
EL-EE-ES's Avatar
that bolt is not needed...its to prevent you from mounting your rear rims up front...
Old Feb 4, 2009 | 10:00 AM
EL-EE-ES's Avatar
there is an extra hole in the rear also with a rubber plug...the hole is there so you can adjust the e-brake
Old Feb 4, 2009 | 10:02 AM
Hi-TechG35's Avatar
The bolt that you are reffering to is simply to hold the rotor on. You can remove it with either a 10mm or 12mm, I forget the size.
Old Feb 4, 2009 | 10:26 AM
Corrosive's Avatar
Cool. As long as I can leave it off then thats whats important to me. I dont have the hole to re mount it once the new brake rotors are up.
Terry_G35
May 9, 2020 01:39 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 31, 2015 11:49 AM
Terry_G35
Aug 4, 2015 02:38 PM
