Odd Spring Question
Old Mar 22, 2009 | 05:46 PM
g30wh4t's Avatar
Odd Spring Question
If I run OEM sport springs up front with 350z S-tech rears will it sit even? My front is a little too low and I also want to eliminate the use of aftermarket A-Arms. Accurate feed back only please.
Old Mar 22, 2009 | 06:31 PM
huyrua's Avatar
Cut your spring mounts.
Old Mar 22, 2009 | 09:22 PM
jlin615's Avatar
So your front is just too low in general? Or is it too low compare to rear?
Old Mar 22, 2009 | 10:10 PM
g30wh4t's Avatar
In general. The rear is perfect, the front is too low. I want to be able to use my stock A arms up front, since the 350z S-techs sit stink bug, I was wondering if it would level out.
Old Mar 22, 2009 | 10:31 PM
jlin615's Avatar
In that case, if you use stock sports springs in the front, then the rear will be sagging.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
