Noise In Front-End HELPPP!!!!!!
Old Mar 25, 2009 | 08:21 PM
alliedtech's Avatar
Everytime i hit a pot hole or pump theres a thumping sound coming from my passengers side front end. it almost sounds like i have a worn shock or somthing. one of my buddys said it could be worn busings or a control arm. plus the car has a slight viberation on the highway over 60 any ideas? my car is a 2004 g35x. thanks
Old Mar 25, 2009 | 08:22 PM
jutn35's Avatar
G35 Coupe
i have the same thump when going up driveways , but its in the rear passenger side,my tech guy at INIFINITI told me it was the bushings
Old Mar 25, 2009 | 08:38 PM
naughty240's Avatar
Prob a compression rod. When mine were bad you could really hear it when I was going slow over any kind of bump. Sounds like a bad strut.
Old Mar 25, 2009 | 09:20 PM
Redpit10's Avatar
Quoted for truth. Its real annoying. The compression rods seem to act up a lot when their on an incline like the second post described. Find a nice incline (driveway preferable) stop and start a few time and if you hear a creaking, thumping, cracking, or any other similar noise then you can be mostly sure that your compression rods are going bad.
Old Mar 25, 2009 | 11:08 PM
maciejk's Avatar
i don't think he's talking about the creak sound that happens when going slowly over bumps that can be taken care of by spraying all the bushings and suspension parts with silicone lube, i get the same thumping sound when driving around hitting holes, sounds like the shock is lose but i tightened and nothing, it is almost constant now on my driver's side annoys the **** out of me, i had a stabilizer bar end link changed that didn't solve anything, i have a fvcking vibration too on the highway it starts at around 65mph right at fvcking crusing speed and gets worse as i let off the gas pedal goes away as i hit the gas pedal again, then after 80mph it goes away, 4 brand new tires with balancing didn't help
Old Mar 26, 2009 | 02:02 AM
Tollboothwilley's Avatar
I'll bet you money its your strut mounts.
I had that problem. Clunking sound. I replaced both my front strut mounts and voila, no more sound.
Old Mar 26, 2009 | 02:03 AM
Sound coming from the rear passenger side is normally the sway bar endlinks . . . stocks are weak with little articulation. Change those and be much happier.
Old Mar 26, 2009 | 02:05 AM
gr8huntr's Avatar
how many miles on yur car??alliedtech
Old Mar 26, 2009 | 02:05 PM
ttrank's Avatar
Grocery getter
Sounds like the control arm bushing to me.
Old Mar 26, 2009 | 04:37 PM
alliedtech's Avatar
THat is exactly what my car does on the high way also.
alliedtech's Avatar
60k
Old Mar 26, 2009 | 05:17 PM
Compression (strut) rod bushings cause a "squeaky" sound which you hear on bumps and turns.
Strut(shock) mounts will just clunk when you go over bumps. When you are going faster (30 mph) it might sound more like a vibration.
Old Mar 26, 2009 | 06:09 PM
alliedtech's Avatar
yea my sound is more of a clunk. are those hard to replace or can i try tightening them?
Old Mar 26, 2009 | 11:17 PM
maciejk's Avatar
hey Tollboothwilley, can you identify which part you have replaced, i don't see strut mounts in the diagram there must be another term for it
http://s112.photobucket.com/albums/n...rent=strut.jpg thanks
Old Jun 8, 2009 | 07:28 PM
tran2000's Avatar
i have that same exact problem. it squeaks when i'm turning left or right and when i go over speed bumps. my car also vibrates starting at 65 and stops at 80.
