Quick question about shims and the hardware kit
Old Apr 1, 2009 | 08:36 PM
naughty240's Avatar
I did a quick search but didnt find too much.
I was reading through FSM and it seems they recommend replacing the brake shims with the brake job. In a few posts I read it seemed like people whom had noise were missing or the grease dried out between the shims. I have no noise and I have all shims.
So my question is, can I just clean all the parts and apply fresh grease? Or do you guys think I should buy the hardware kit. Its like $110 for the front and rear kits. Im already over my budget on this so if its not a big deal I would really like to reuse the hardware
I have a rwd sedan with 72k
I have hawk pads and stop tech rotors on the way from Riverside.
Old Apr 1, 2009 | 10:55 PM
obender66's Avatar
At 72 K you are very likely to need new shims, espeically if you never changed brakes. I did my fronts at 40K km and they were all rusted out-I am not sure about your winter conditions. I still reused them, but clicking noise drove me crazy and I had to take everything apart again and install new shims. I did another brake job since then and reused old hardware, it was in OK condition.
Old Apr 1, 2009 | 11:19 PM
naughty240's Avatar
Ive only had the car since 59k and im pretty sure the previous owner was in a snowy climate too. I see what you are saying. It may be ok now but in 10k it may not be. Too bad you cant just get the shims.
Old Apr 2, 2009 | 10:39 PM
obender66's Avatar
You can get just the shims. It will be same $50 per front or rear set.
Do your brakes and reuse the shims. If they start making noise get new ones and put them on-this is an easy job.
Old Apr 2, 2009 | 10:59 PM
naughty240's Avatar
Thanks obender, I actually said F it today and just ordered both kits, I hate doing stuff twice and with my luck in 15 miles it would make noise.
Now im thinking stainless steel brake lines haha
Jusseth
Sep 13, 2020 12:25 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
