7500 miles in and Warning on speedometer?
Just hit 7500 miles and the first thing was the maintenance pop up which is normal but I've been getting a Tire warning from the display in the speedometer area is it a regular maintenance or is it something else?
My low pressure light isn't on and i checked it and it's fine so i'm kinda puzzled
It has a special microprocessor which detects which tires are at which corner, and how much they rotate, when they reach a predetermined rotation level, they set off the warning light....
J/k, I hope you guys aren't serious, but that light is just to tell you it's about time to rotate the tires... If you have staggered tires, just disregard that warning and reset the light, if you have same sized tires front and rear, have them rotated.
Infiniti generally has the maintenance lights set at 3750 miles for the oil changes, and 7500 miles for rotation of tires, just check your manual.
mjfenix
Jul 17, 2015 02:07 PM
