Bushings, cracked
Old Apr 14, 2009 | 05:35 AM
jutn35's Avatar
G35 Coupe
Question Bushings, cracked
So i took my G to my tech guy at INFINITI, and he has told me that my bushings are cracked which explains why my car has been making this pop noise going up driveways. I did use advanced search, but all i found was this.
https://g35driver.com/forums/brakes-...-coverage.html
i have no warranty and my question is , how much would it be for the parts. Im sorry if im not as detailed.
Thanks
Old Apr 14, 2009 | 10:31 AM
eurodre's Avatar
did you ask infiniti while you were there how much it would cost?
Old Apr 14, 2009 | 11:43 AM
JZ39's Avatar
For me, that noise was a bad rear sway bar link. Exactly as you said, when one end of the rear goes up the driveway and then the second you hear like a clunk noise.
How many miles on your car? Strange that the bushing is bad--this is just a hard piece of rubber. I examined my bushings when I put in my adjustable shocks and at 35000 miles they looked like brand new.
Rear sway arms are like 20$ for the pair.
Old Apr 14, 2009 | 11:47 AM
Boston's Avatar
Jutn, the compression rod issue is a known one and many members have had their compression rods replaced under warranty or at their own expense. At the time I replaced mine, there was no fix for replacing just the bushing portion of the rod. I suggest PMing Tony at Riverside for replacement compression rods as he had the best price for me when I replaced mine out of warranty.
Old Apr 14, 2009 | 12:45 PM
jutn35's Avatar
G35 Coupe
He said he doesnt know at the top of his head
Old Apr 14, 2009 | 12:49 PM
jutn35's Avatar
G35 Coupe
Thats what I was told sometime ago, about the compression rod, but i had the Rear Axle Click fixed, and thats when he examined my car. But I'll pm , thankyou for your info and help
I have about 39k and its a 2003, but sounds like you had the same problem. like going up a driveway or speed bump, just a POP/CLUNK. But I'll look into yours as well. Ive been driving on it way too long
Thanks
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
