SPC camber/toe kit question
Old May 13, 2009 | 08:03 PM
noize's Avatar
OK, I've just ordered an SPC rear camber arm kit with toe bolt from here for $90.00
http://www.iapdirect.com/product.php...cat=355&page=2.
I end up getting these(set of 2) in the mail today.
Is that all that is need to adjust the Camber ±3.00 degree and Toe ±3.00 degree as specified on their website? I was expecting an additional control arm like these .
Sorry for the newbie question. I'm just confuse on what exactly to get to adjust my rear camber and toe.
Old May 13, 2009 | 08:18 PM
redlude97's Avatar
You will get 4 of those bolts to replace the OEM bolts on the factory camber arm and on the end of the spring bucket. You will not get camber arms. I recommend changing your order to the kit with the camber arms and toe bolts instead.
Old May 13, 2009 | 08:23 PM
roblo's Avatar
you need 2 arms for camber and 2 bolts for toe
Old May 13, 2009 | 08:53 PM
noize's Avatar
So basically what I got above are the two bolt for toe adjustment only? Then why the website said "Rear Adjustment range: Camber ±3.00! Toe ±3.00"...that confuses me to think I could adjust both.
Redlude, can I just keep the the two cam bolt and order 2 cam arm seperately instead? That way I have 2 arms for cam and 2 bolts for toe for a complete set.
Old May 13, 2009 | 08:54 PM
redlude97's Avatar
You cannot order the arms separately. All the arm kits from SPC come with the bolts
Old May 16, 2009 | 12:41 AM
syshs's Avatar
Check with these 2 vendors... you never know... they might just sell you only the 2 arms that you need...
https://g35driver.com/forums/suspens...tires-___.html
https://g35driver.com/forums/suspens...ck-em-out.html
Old Jun 28, 2009 | 03:06 PM
MEMO187's Avatar
where it says options it gives u a choice for just toe bolts for $45 or toe bolts and camber adjustment for $90.... they probably got confused??
Jusseth
Sep 13, 2020 12:25 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
