SPC A Arm Problem installation
Old May 14, 2009 | 05:23 PM
tightvpkid's Avatar
Bought the SPC A-arm in 2007 and i guess i bought the ones without the spacer(updated kit), so i'm starting to have issues with the Arm hitting the upper inside on hard turns and bumps. Called SPC and they said they will send out the new kit to fix that problem. Anyone know how to install this or have any pictures or a DIY thread on how to install it. The SPC tech guy was saying something about it going over the strut and said no need to get a realignment or anything. Did a search but found nothing.
Old May 21, 2009 | 06:17 PM
RST531's Avatar
my bad, your were talking about SPC not SPL.
Old May 21, 2009 | 06:26 PM
G35Papa's Avatar
You will need to drop the strut in order to remove and install the control arm. I'm not sure what spacer they are talking about unless its the one that goes behind the hub. Post a pic if you can.
You will also need to make sure the caster and camber settings are the same as what you have now on the new arm.
I have the same issue with the arm bottoming out (hitting the top) and I have the revised kit. I was told that because of my drop height, I have gone beyond the normal working conditions of the kit
chinee
Jun 10, 2024 07:48 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
attarday
Jul 15, 2015 04:03 PM
