05 Coupe 19inch/sprts pkg rotor question
May 23, 2009 | 11:06 AM
If this question has been done 1000 times my apologies. But are the rotors exactly the same for all 2005 coupes regardless of wheel size and pkgs? I am shopping to replace my rotors and pads and have the 19inch factory wheels with the sports pkg....
Thanks!
Reply 0
Nov 30, 2010 | 07:36 AM
Yo COMMANDOE,
More will weigh in, but I suspect they are the same regardless of wheel/tire packages..........except if you opted for the Brembo brake package, which - I'm pretty sure - is only tied to the sport package.
(I have an auto trans 06 coupe, essentially missing only nav & satellite radio packages.)
More specifically, when I got my brake pads changed - not by Infiniti, but my local wheel-tire-suspension expert in S. Florida (for 60 % less, I might add), I made sure I specified non-Brembo appropriate pads.
Needless to say the entire job costing $116.00, installed, hints to non-Brembos......300 beans, mi culo, Infiniti. But I digress; showed the wife a good time with the savings. And had some change.
As a last resort, you could probably ring your local Infiniti technical (service dept.) folks, but this site has plenty of expertise, so hopefully somebody - a DIY type - with way more knowledge than I will give some input.
Rock on!
Reply 0
Nov 30, 2010 | 01:52 PM
Yes, all '05 coupes have the same size rotors (12.6" x 1.1" front and 12.1" x 0.63" rear) regardless of wheel/tire or sport tuned suspension package.
http://infinitihelp.com/models/2005/...ifications.htm
And, Bozo - FYI - the Brembo brakes were only offered on the '03-'04 6MT coupes and were discontinued in '05.
Reply 0
