bending a-arms to fix camber ?????????
Old Jun 10, 2009 | 10:48 PM
g35maraj's Avatar
anyone know about this, i dont want to buy a camber kit for the front to fix my uneven tire wear, so would this fix my problem, i posted something like this and someone said bending it might fix it??? help fellas
Old Jun 10, 2009 | 10:54 PM
GLuXuRy's Avatar
i wouldnt recommend that .. due to the fact that its going to be hard to make them even .. plus .. im not entirely sure if bending the upper A arm would even change camber .. if anything you would have to extend or shorten the the length of the arms .. if you do bend it .. i would think it would end up hitting something
Old Jun 10, 2009 | 10:56 PM
MikeYo's Avatar
you sir are cheap!
Old Jun 11, 2009 | 01:25 AM
mosoto's Avatar
IIRC you can't "bend" cast aluminium and expect it to retain rigidity or strength.
Old Jun 11, 2009 | 01:46 AM
lilindienplaya's Avatar
I would never even think about doing such things to a suspension item like that, if i remember right they use cast aluminum and if thats true then bending it will make about as strong as a brick, you hit one bump or put any strain on it and bam it will snap. If i were you it would be smarter to just live with the tire wear or buy CK
Old Jun 11, 2009 | 02:04 AM
Canadian's Avatar
Canada, eh?
Even if it was possible it would be impossible or at least very very very hard to align it correctly...it would cost more for the machine/tools to do it than the camber arms. Don't be cheap and buy a pair.
jilljann1
Jul 21, 2020 08:12 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
