Suggestions with setup
Old Jun 12, 2009 | 04:33 PM
hawaii's Avatar
Hey guys, I just wanted your opinions before I finalize my setup. I have an 04 sedan and wanted to go with SEDAN H techs (1.4, .7 drop) and 19" OEM rays with 245/40/19 all around. My question is, will I have any camber issues with this setup? If so, should I just go with the G/Z spring combo? I do not want to get into a camber kit or premature wear on my tires What do you guys suggest the best setup is for me?
Thanks in advance
Old Jun 14, 2009 | 04:28 AM
hawaii's Avatar
Anyone? I know some sedan owners can help me out here
Old Jun 14, 2009 | 11:23 AM
Gsedan35's Avatar
A 33mm or 30mm 8" wide rim mounted to a 245 wide tire will rub the outer fender lip on the front of a sedan if your corner hard enough. Maybe you'll experience that, maybe you'll never push the car hard enough to know.
Set your toe right after the spring install and you should be fine.
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
