sway bar bushings
Old Aug 1, 2009 | 11:44 AM
RaginRaj11's Avatar
sway bar bushings
The bushings on my sway bars are cracked. Is it ok to install the bars even though they are cracked or should i use my stock bushings?
Old Aug 1, 2009 | 12:16 PM
Boston's Avatar
I wouldn't use the OEM bushings if they're cracked and worn. I got prothane bushings when I installed my Stillen sways 3 yrs ago. Get the small packs of grease too and lube the inside of the bushing so you don't get the squeaks.
http://www.jegs.com/p/Prothane/Proth...62160/10002/-1
Old Aug 1, 2009 | 01:23 PM
RaginRaj11's Avatar
the oem bushings on the stock sway bars are fine. The bushings that came with the eibach sway bars are cracked.
Old Aug 1, 2009 | 01:25 PM
GLuXuRy's Avatar
^^^use the OEM bushing on the eibach sways for now .. and get some poly ones later
Old Aug 1, 2009 | 01:28 PM
RaginRaj11's Avatar
thats what i was thinking. Thanks!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
