Camber Kit ?
Old Aug 27, 2009 | 06:45 PM
Libra4220's Avatar
Exclamation Camber Kit ?
Just wandering, I need to adjust my camber to correct the tire ware that my alignment angles are creating, totally messing up my tires, I have seen some of those adjustable camber control arms and strut kits but do I have to replace the lower ones as well? even though there are no lower control arm camber adjustments don't know if you have to do both, thanks for any tips...
Old Aug 29, 2009 | 12:50 PM
jwrape's Avatar
The answer is yes, it has been discussed MANY times on the board.
If you are lowered at all you will at least need a rear Camber kit to correct the camber. Depending upon how lower you are in the front you will might need Camber Arms in the front.
Old Aug 29, 2009 | 04:52 PM
Libra4220's Avatar
Well I really just wanted to be able to adjust my front camber angles because of the tire ware and all, I think I G is low enough because I scrape coming into my parking lot of my appartment and the rear tire ware is good. so all I should need is the camber arms and strut tower kit for the front then ,if Im not lowering it anymore right?
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
