Koni Vs Tokico D-specs?
Old Sep 7, 2009 | 08:44 AM
manbart's Avatar
Koni's more expensive. Are they better? Are Koni's available for 2004 G35X?
Tilf
Old Sep 7, 2009 | 09:07 AM
RBull's Avatar
Rated M
I don't know anything about the Koni's but the D Specs were awesome. Wide adjust ability and a nice step up from OE.
I just sold mine to another member on here.
Old Sep 7, 2009 | 10:10 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^+1
Tokico are fantastic bang for the buck.
Old Sep 7, 2009 | 02:43 PM
GT-ER's Avatar
I had Koni's on my GTI and they were the best shock I have ever had ( and I've had a few including biltein shocks which are also great ). I've had tokico on other cars and I have never been too impressed with them until I tired the D-specs on my G-sedan. They were also fantastic. While maybe the Koni's might be slightly better, I highly doubt there is a big enough difference to justify the steep price.
Old Sep 7, 2009 | 02:52 PM
dofu's Avatar
20 Year Member
Originally Posted by Gsedan35
Tokico D-spec twin tube 8 way double adjustable (bump and rebound) gas shocks 2 fitment's are sold DSP-7 for the G35 and DSP-9 for the 350Z.
The only difference between the DSP-7 and 9 is that the rear shocks on the DSP-9 350Z fitment feature's shocks that have shorter bodies by 3/8" and piston shafts that are 1 7/8" shorter The 2 fitment's are both valved the same. These shocks can be set from softer then oem G35 shock to stiffer then the oem 350Z shock, your choice depending on how you set them.
$489
Side note: Do not run them with any spring that is beyond 450lbs, cannot be revalved, serviced by Tokico USA only.
Koni Sport SA twin tube shocks Single adjustable for rebound.
Side note: IMO, do not run spring rates above 400lbs in the front and 450lbs in the rear, without having them revalved. Can be serviced, revalved, shortened, even converted to double independent adjustablity for seperate rebound and compression control by several authorized Koni service providers.
Side note 2: Better choices exist, this shock works well for many, however it's twin tube construction is it's own enemy. It has a fair amount of hysteresis, which does cost the owner grip and a lose of ride quality.
$700-$800+
https://g35driver.com/forums/brakes-...w-updates.html
I agree that Koni makes some great struts, but for some odd reason, that isn't the case with the G35...
Old Sep 8, 2009 | 08:29 PM
Higrev's Avatar
tokico!
Old Oct 24, 2009 | 08:24 PM
G354DR03's Avatar
im new to suspension tuning and was thinking about buying a set of Tokico D-specs along with tein h techs...would this be compatable? or do i have to go with tokico springs?
any feedback would be greatly appreciated
Old Oct 24, 2009 | 08:45 PM
dofu's Avatar
20 Year Member
As long as you're buying G35 specific parts, you can mix and match springs and struts all you want. Some guys like mixing and matching Z suspension parts in too, but there might be issues with rear spring rates and/or strut compression on the G coupes.
DRG35R
Sep 16, 2015 05:33 AM
spanky99l
Sep 7, 2015 12:46 AM
TheBay
Sep 3, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
