Will alignment be covered under full warranty?
Old Sep 26, 2009 | 10:30 PM
raydeon's Avatar
dealership is closed until monday....my car vibrates when i hit the brake so very much likely it's an alignment issue. wonder if it will be covered under full bumper to bumper warranty (i still have 2 more months on it).
thx
Old Sep 26, 2009 | 10:43 PM
eedmond's Avatar
sounds more like your rotors need to be turned
Old Sep 26, 2009 | 10:55 PM
GEE35FX's Avatar
^^^+1 definitely sounds like a brake problem such as warped rotors.
Old Sep 26, 2009 | 11:02 PM
velomack's Avatar
Sound like you have warped or a flat spot in your rotors. Alignments are more for when you feel your car pulling to the left or right. Not sure if your bumper to bumper will cover, but take it in and have them tell you whats wrong.
Old Sep 27, 2009 | 02:56 PM
Q45tech's Avatar
Alignments are wear and tear not covered after 12,000 miles or 1 year. As the rubber bushings and isolators wear and are not covered either. Bending doesn't count only breakage of components [failure].
Anyway rotors, tires, and wheels [things that rotate] are the only components that get out of balance and set up vibrations.
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
