Rear Brake Noise
Old Sep 29, 2009 | 04:25 PM
B T's Avatar
B T
Rear Brake Noise
While driving, if I pull the E-brake I hear a loud thud/crunch coming from the rear passenger side. Only happens if it's pulled while driving. I've checked the rotors for built up rust, checked the brake pads and even the brake piston for seize but no solution as of yet. If I do it, it goes away for a while (maybe 15 minutes) and then it repeats if I pull it up again. Im thinking its the piston, but dont want to bother jacking/removing and the likes of again. Anyone had a similar issue or suggestions?
Old Sep 29, 2009 | 04:40 PM
ttrank's Avatar
Grocery getter
The e-brake is inside the rear rotor hat. It's a drum style e-brake.
Sounds like you need to take it into a shop as the drum pad may be damaged.
Old Sep 29, 2009 | 05:34 PM
5150DS's Avatar
Don't pull the ebrake when you are driving.
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
papo020
Jul 17, 2015 10:30 PM
emorehs
Jul 17, 2015 09:45 AM
