so freaking irritating...
ok... im really irritated. i have my car lowered on the tein basics now..
ok so heres the problem. the rear is lowered to the max. the front however has alot more to go. it seems like the front is at the same height... but the rear is not the same height. left side is higher than the other...
it may not be noticeable from far away, but up close it really bothers me. does lowering the front affect how low it will be in the rear, even if the rear is maxed out? or is it because my front might be uneven also? help a brother out please. thanks.
now this is just me, but height in the front doesn't effect the rear. your side to side is a easy fix. what i did when i installed my basics was adjust the height before installing them. i put the springs/coilovers next to each other to make sure they were exactly the same length. the first time i installed mine, i took the car off the lift to see the height and the front was WAY to high so i pulled the coils off and dumpt it. it might be a chore but you can pull both front wheels off and use a tape to measure from the bottom of the adjuster to the bottom of the threads. just my opinion though.
hmm.. well this is a problem. IF i knew how to take the coils off, like literally off the car then i would, but my friend help me put it on. I dont want to go through the hassle of taking it out. the front, really looks like the same height for some reason, but the rear is off and both sides are maxed out... its really irritating. im just confused and frustrated.
Frostbite91
Aug 20, 2015 07:20 PM
