Quick camber question
Old Oct 24, 2009 | 12:02 PM
GBoy's Avatar
I drive 03 sedan and my right camber is -1.3 degrees and my toe is within spec do I need a camber kit or simply swap the tires twice a year..
Thanks
Old Oct 27, 2009 | 05:31 PM
GBoy's Avatar
Nobody?...........I was at Nissan getting an oil change and spoke to the service manager and he mentioned that he had heard of shims and he would look at the car but I did not have enough time, could slight camber be fixed
with some shims..
Old Oct 29, 2009 | 01:40 PM
The Stimulation's Avatar
You're fine, don't worry about it. I think OEM camber is -1 degrees so 0.3 degrees is not going to affect much. Since your toe is in spec, you're good to go.
Old Oct 30, 2009 | 06:31 AM
GBoy's Avatar
According to my last alignment from Infiniti for the 03 sedan spec camber up front should be between -0.50 to +.40 so am I still good to go..
Old Oct 30, 2009 | 10:35 AM
Q45tech's Avatar
The FSM shouws a NOMINAL or ideal setting which is the EXACT midpoint of the in warranty range.
The range is created so that dealers can check brand new cars for transport damage.
Ideal = Ideal
As the rubber bushing change and wear or the suspension bends things progressively creep away from ideal or new. Alerting owners to the need to replace wear and tear or curb damaged components.
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
