3 lights on dash and brake lights don't work...
Old Nov 2, 2009 | 02:09 AM
MAXIMA to G35's Avatar
Description of problem:
I start the car and everything appears fine. The brake lights light up. Once i press the brake pedal past a certain point (about 1 inch??) 3 lights pop up on my dash: "abs", "slip", and "vdc off". Once these lights show on my dash, the brake lights stop working. When I turn the car off and back on, the lights are gone from the dash but the brake lights still don't work
Trying to avoid the problem:
I've changed my driving habits now to avoid the lights popping up on the dash and thus making my brake lights stop lighting up. I slow down way in advance so I don't have to press the brake pedal too far down. I also down shift when I can to help. (6speed). But sometimes I have no choice but to press down the brake pedal past that point, like when coming to a short stop going down a hill. I am constantly checking to see if my brake lights light up by looking for the reflection off the license plate of the car behind me. Sounds ridiculous I know but I realized how dangerous it can be to drive without brake lights.
Trying to fix it:
I replaced the stop light switch(located over the pedal) and checked for codes and reset it. The lights on the dash never showed up and the brake lights worked for about 2 weeks, then the same problem came back. The code that came up was "pressure sensor circuit".
What is the pressure sensor circuit and does it need to be replaced? What else can be causing this odd problem?
thanks for taking the time to read this. any input will be helpful
Old Nov 2, 2009 | 04:04 PM
pfarmer's Avatar
What year is this 35 and miles?
In any case make sure your brake fluid is full and I do mean up to the full mark.
Old Nov 2, 2009 | 09:13 PM
Sorry, I guess I forgot to mention that part.
2003 g35 sedan 6speed
56k miles
Sepsis
Feb 12, 2020 02:05 PM
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
