Need help picking suspension - newbie
Old Jan 5, 2010 | 10:15 AM
Mr_pharmD's Avatar
I;m really new at the suspension part of the mods and I would like to upgrade from my current setup to something really similar. As of now I'm just running Tein 350z H springs with stillen sways. I like the stiffness of the 350z H but just dont like the rear drop so is there anything comparable to these in coilover rating? Would I be able to buy adjustable struts with damping (if there are any??) to adjust the ht and ride and still reuse my tein springs?
Old Jan 7, 2010 | 09:02 AM
DailyDrivenCoupe's Avatar
have you looked at the s-techs for the g35. when you buy springs for the 350z the drop isn't as much as if you ordered them from a g35. search for spring rates and compare between h-tech and s-tech. just don't forget to order them for g35 if your looking for more drop
Old Jan 7, 2010 | 09:23 AM
GreenGoblin's Avatar
The goblin resurrection
You will not be able to reuse the springs if you want to lower the car more. If you are only looking for a little bit more in the rear you should try trimming the spring mount. It is a cheap part $40 for both and takes not very long to complete it.
Old Jan 7, 2010 | 05:46 PM
06PlatinumG's Avatar
You have that backwards, if you buy 350Z springs and it states 1" drop on the Z you will get 1.5" drop on a G35 coupe and 2" on a sedan. Always add .5" for the coupe and 1" for the sedan when looking at Z springs
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
1OG35
Aug 7, 2015 11:25 AM
