Caster question
Old Jan 6, 2010 | 09:33 PM
5150DS's Avatar
Caster question
I just had my tires replaced an an alignment done. According to the specs I am within the normal range. However, my Cater is at 8.5 on the left and 8.3 on the right. According to the sheet the normal range is 3.8-5.3. Will this caster setting cause me any kind of problems? I wouldn't mind a simple explanation of caster either so I can fully understand it. I am familiar with camber and toe, but not caster.
Thanks in advance.
Old Jan 6, 2010 | 10:24 PM
06PlatinumG's Avatar
Caster is the tilting of the uppermost point of the steering axis either forward or backward (when viewed from the side of the vehicle). A backward tilt is positive (+) and a forward tilt is negative (-). Caster influences directional control of the steering but does not affect the tire wear and is not adjustable on a G35. Caster is affected by the vehicle height, therefore it is important to keep the body at its designed height. Overloading the vehicle or a weak or sagging rear spring will affect caster. When the rear of the vehicle is lower than its designated trim height, the front suspension moves to a more positive caster. If the rear of the vehicle is higher than its designated trim height, the front suspension moves to a less positive caster. With too little positive caster, steering may be touchy at high speed and wheel returnability may be diminished when coming out of a turn. If one wheel has more positive caster than the other, that wheel will pull toward the center of the vehicle. This condition will cause the vehicle to pull or lead to the side with the least amount of positive caster.
Old Jan 6, 2010 | 10:59 PM
5150DS's Avatar
I am lowered on 07 Z springs front and rear on an 05 sedan. Could this have cause the positive camber?
Old Jan 7, 2010 | 02:00 AM
It's possible if the rear was lowered further than the rear. I wouldn't worry about having a little more positive caster. It's negitive caster that can be bad.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
