springs question??
Old Feb 5, 2010 | 02:01 AM
dcrxridha's Avatar
Question springs question??
I just install my tein s tech springs on my 04 sedan and I had a question. Is it normal to hear a little banging noise, nothing big. Coming from the front when I go over a bump or something ? I tighten everything and still don't know what it is. Has this happen to anybody?
Old Feb 5, 2010 | 01:12 PM
813G-WHiP's Avatar
i'm new to infinitis, but check control arm bushings, sway bar components, or strut towers..
Old Feb 5, 2010 | 02:45 PM
nghiars's Avatar
was the spring seated correctly?
Old Feb 5, 2010 | 03:09 PM
Holmes35's Avatar
no def not normal to hear this noise...after i installed springs i had a little creak in the front right wheel well and had infiniti check it and i believe it was the control arm bushing or something small that needed replaced...if your dealer is cool with mods then they can probably tell you if not have a local mechanic look if you cannot figure it out
Old Feb 6, 2010 | 12:12 PM
dcrxridha's Avatar
i checked everything and still cant find whats wrong with it fml!!!
Old Feb 6, 2010 | 12:24 PM
4DGS's Avatar
What kind of wheels do you have and what are the specs on those and your tires?
Is there any rough gouges on your tires tread?
Old Feb 6, 2010 | 12:29 PM
dcrxridha's Avatar
i got the stock17s and naw they are not touchin nothing there is enough space for them
Old Feb 6, 2010 | 12:36 PM
4DGS's Avatar
How much give does your front end have when you push on it with your hands? Does it feel squishy with little resistance?
Old Feb 6, 2010 | 12:39 PM
dcrxridha's Avatar
a lil not dat much is more stiff than before but i know thats because of the springs
Old Feb 7, 2010 | 11:22 AM
G35Papa's Avatar
Check your end links and swaybar bushings
Old Feb 7, 2010 | 01:04 PM
KevcoG35's Avatar
Could it be your shocks bottoming out? If you're running OEM shocks, they may be a tad long.
Old Feb 7, 2010 | 02:44 PM
dcrxridha's Avatar
i notice today that the noise is coming from the right side
Old Feb 8, 2010 | 02:53 PM
10nara's Avatar
If everyting is tight and you hear a knocking noise, it might be blown shocks. I had that issue before. Replaced shocks and it went away. Took me a while to figure it out though.
Old Feb 9, 2010 | 08:31 PM
dcrxridha's Avatar
did it make the noise when going over speedbumps? i thinks my right 1 is blown
Old Feb 9, 2010 | 11:39 PM
Hearno's Avatar
Post pics of your ride with the new springs!
