suspension/camber help
Old Feb 13, 2010 | 09:42 AM
christophg35's Avatar
Question suspension/camber help
so im about to buy 350z stechs for my 04 coupe and put 25mm wheel spacers all the way around. i imagine ill be needing rear camber arms and toe bolts, but what about the front? will i need a front a-arm to get the front camber back into specs or will it be fine without?
what brand of front and rears are good to go with?
Old Feb 13, 2010 | 09:59 AM
LordFappington's Avatar
Depends on what offsets youre running now and if youre looking to pull it back to spec or swang'n'bang.
Old Feb 13, 2010 | 10:02 AM
i have the oem 19's and im looking to get it as close to spec as possible...i wanna preserve my tire life because its my daily driver
Old Feb 13, 2010 | 10:27 AM
tragedycat's Avatar
You'll need front and back camber arms.
Old Feb 13, 2010 | 10:34 AM
Just camber arms should do it. I recommend Ichiba. If youre looking to pull it into spec though, you may need to roll the fender or stretch your tires some.
