Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
What one should i get?? Im getting stances and plan on being very low.. I can get the spc for 550 shipped.. Not sure if ichiba are cheaper.. What do you guys recommend?? Im on somewhat of a budget..
the Ichiba are definitely cheaper than the SPC. I've used them for almost a year with no problem whatsoever, but I just replaced them with SPL ones. You might see a set for F+R very soon in the marketplace.
Frankieg35
close
- Join DateOct 2006
Why did u replace them?? Do they come with toe bolts?? If your selling them I may be interested.. How many degrees do they adjust??
I replaced them for no real good reason, other than that these SPL ones come with non rubber bushings and since I am changing out all of the bushings on my car (cause of old age) I took the dive.
Yeah, the ichiba rear camber kit comes with toe bolts.
Frankieg35
close
- Join DateOct 2006
Do the bushings make noise?? How much u selling them for??
The camber kits don't make any noise at all and the bushings in them are in practically brand new since I've only driven the car for a 1000 miles in the last year.
Really haven't thought about price yet, but I'm guessing somewhere in the mid 300s for the Front and Rear.
Frankieg35
close
- Join DateOct 2006
How many degrees do they adjust?? If and when u plan on selling let me know first.. I'm looking to get a kit within the next month or so..
+/- 3 degree of camber for the front
+/- 4 degree of camber for the rear. Not sure how much toe it can adjust though.
As a reference, I'm dropped 1.5" all around with Tanabe pro5 coilovers and my alignment specs are all within factory spec with room for more adjustment.
Sure, I'll let you know first. I'll send you a PM when I do, but they will definitely be available for sale within one month.
Frankieg35
close
- Join DateOct 2006
Ok kool thanks I appreciate it.. I'm gonna be dropped on stances so I plan on going very low.. I have aggressive wheels I just need them so I don't have to run as much negative camber.. I hope they will work out..
i just bought front spc ones. I think Ichiba is fine aslong as u get the same specs as spc
Frankieg35
close
- Join DateOct 2006
What are the specs for spc?? Can u get itchiba in different specs??
If you're going to be slammed, there's a good chance that the ichiba front arms won't get you back in factory specs. It's rumored they only offer about 0.5 degrees of positive camber adjustment up front versus the SPC kit that offers 2 degrees of positive adjustment. Search other threads on the ichiba fronts and there are a fair number of people who weren't able to get back into spec with them.
Frankieg35
close
- Join DateOct 2006
I'm not gonna be back in specs with my wheels I don't think.. The fronts are 20x10+11 with a 235/35 tire..I plan on tucking the tire.. Can someone verify if the ichiba kit will work for me.. If not I guess I will have to get the spc kit..
alfhasg35
close
- Join DateFeb 2005
- LocationOrange County, 714, 92780
iTrader Positive Feedback100
iTrader Feedback Score(78)
Liked:295 Times in 183 Posts
i've heard if you are going lower than 2", the ichibas are not for you.. iirc
Frankieg35
close
- Join DateOct 2006
It's looking like I'm gonna be going with the spc kit..
