Tanabe 350z springs vs G35 springs
Old Feb 19, 2010 | 10:17 AM
reverse's Avatar
Try'n to to find which would give a lower drop. 350z Tanabe GF210 or G35 Tanabe DF210?
Old Feb 19, 2010 | 12:41 PM
Higrev's Avatar
According to their site DF210 for the G35 is about 1.7/1.5 (http://www.tanabe-usa.com/df210.asp?id=1)
And the 350z GF210 are 1.0 and 1.2 http://www.tanabe-usa.com/gf210.asp?id=3
Looks like the DF210 are lower...
Old Feb 19, 2010 | 01:02 PM
SuperStezzyG's Avatar
350z springs will go 1/2 lower on g35 coupe.. GF210 will be 1.5 front and 1.7 rear
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006 (revised suspension)
Front:314 Rear:427
Tanabe DF210 G35 COUPE progressive springs 1.7”/1.3” drop on G35 coupe, G35 sedan drop will be higher
Spring rates in LBS 308 /353
Beware, a 1.7" drop in the front on a spring that is softer then oem
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
https://g35driver.com/forums/brakes-...w-updates.html peep it out!
Old Feb 19, 2010 | 01:13 PM
reverse's Avatar
yeah, i looked at that. but couldn't really tell how much more would he drop be using the 350z. THNX....
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
