Tire scraping
Old Feb 26, 2010 | 10:39 PM
turbopowurd's Avatar
Tire scraping
I have a 04 g35 coupe with the sport package and some after market 20" in the front and rear. I just recently replaced the tires on my 20's from toyo to yokohama s drives. For some reason there is a scraping sound every time i hit a slight bump, which never happened with the toyo. I am not sure if my struts and springs are just getting worn (~60k miles) or if the tires are wide enough to scrape the wheel well.
Any suggestions or knowledge would be helpful.
Old Feb 27, 2010 | 11:59 PM
Sen's Avatar
Sen
What's the size of the new tires? What was the size of the previous tires? Any suspension mods?
If you're stock suspension, I wouldn't think you would have any rubbing no matter how wide you go.
Lowered? Then you're probably rubbing cause your new tires are wider.
Old Feb 28, 2010 | 08:52 AM
money042's Avatar
^ exactly what he said.
And as for your shocks/struts getting worn down at 60k, it all depends on how crappy the roads are that your drive on.
Old Mar 5, 2010 | 01:35 PM
roads are decent, no suspension mods at all and they are 275 in the back
Old Mar 5, 2010 | 01:37 PM
This problems been bugging me for a while, the scraping does not happen as often now, but when i have a heavy passenger the noise comes back, and it sounds like the tire is going to destroy the wheel well
Old Mar 5, 2010 | 01:49 PM
kvangil's Avatar
What were the specs on the old and new tires? 275/??/?? Perhaps the new ones are just a bit too tall, hence the scraping.
Old Mar 5, 2010 | 02:02 PM
myroncuz's Avatar
width and offset on rear rims as well..
R350k5
Oct 1, 2015 08:41 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
