Suspension - Uneven drop
Old Mar 20, 2010 | 01:20 PM
757_G35's Avatar
Hello everyone! I had a quick question. I tried searching, but couldn't find anything. Anyway, I just installed some H&R springs and my G is sitting lower on one side (driver side). The passenger side is about 1/4" higher. Also, I had H-Techs last week and it was the same. So, I got the H&R. Still the same. So, it's definetly not the springs. Now, I got 2 set of springs. Alignment maybe? Any thoughts or suggestions???
Old Mar 20, 2010 | 02:11 PM
iiiiiekoiiiii's Avatar
You're not alone. WIth stock suspension (struts,shocks) it's always like that.
My driver side is tucking 1 rim, which gives more camber for lower offsets.
other side is easily more then a finger higher.
Solution. COILOVERS>
Old Mar 20, 2010 | 09:15 PM
extremepowderco's Avatar
Im having the same issue! But it only seems to be the pass rear thats higher about 1/4 to 1/2! The front is sitting about even not much of a diff in the front springs! Im running 350z H-Techs with stock style kyb struts/shocks. Im thinking of doing the rear spring mount mod to level the rear out if no one has a better i idea! Anyone have an idea how to fix this?
Old Mar 21, 2010 | 01:25 AM
EL-EE-ES's Avatar
dennis check your pms
Old Mar 21, 2010 | 07:17 PM
757_G35's Avatar
Got it. Thanks!
Old Mar 21, 2010 | 07:19 PM
757_G35's Avatar
O, so I'm not the only one then. It's weird though. I've had plenty of cars lowered before, but this is the 1st time I've experienced this.
Old Mar 27, 2010 | 04:58 AM
6MTG354ME's Avatar
Tein 350z htechs. Driver higher than passenger. Worn Strut one side? Softer spring? I dont know. GOing to get coilovers.
Old Mar 30, 2010 | 09:15 AM
Kinma's Avatar
I have the same problem. I put 2003 350Z springs onto my 2004 G35 coupe and my passenger side is higher by a 1/4 inch. I also need an easy solution to this. Anyone?
seagrasser
May 3, 2022 09:43 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
toadfire
Sep 21, 2015 07:15 AM
3-fity
Steering & Suspension
Sep 20, 2015 05:05 PM
NJ6MT
Sep 10, 2015 08:40 AM
